- 2026-10-21 On-Premises V2.0.1
- 2026-10-14 On-Premises V2.0
- 2026-08-17 On-Premises V1.7.1
- 2026-08-06 On-Premises V1.7
- 2026-06-16 On-Premises V1.6
- 2026-04-29 On-Premises V1.5
- 2025-12-23 On-Premises V1.4
- 2025-10-14 On-Premises V1.3
- 2025-06-10 On-Premises V1.2
- 2025-02-27 On-Premises V1.1
- 2024-09-24 On-Premises V1.0
Release Notes
V2.0.1 introduces the built-in Plugin Framework for DJI FlightHub 2. It is currently available in beta in China, with availability expanding to other regions in future releases.
I. On-Premises Feature Improvements
1. New Device Support
DJI FlightHub 2 now supports DJI Dock 4.
⚠️ Usage Restrictions
DJI Dock 4 currently supports only HTTPS. You must enable the HTTPS option in the Admin Console. For details, refer to the Switching Between HTTP and HTTPS chapter in this deployment manual.
2. Cluster Architecture Support
Starting with V2.0, a Cluster architecture provides High Availability, Load Balancing, and Disaster Recovery to support larger-scale, more reliable, and more secure flight operations. Visual operations, fewer deployment environment dependencies, and higher deployment success rates also reduce deployment and maintenance costs.
DJI FlightHub 2 deployment starts with a single Node, and additional Nodes can be added as business needs grow. When the number of Nodes is ≥ 3, the Cluster provides the following features:
- High Availability: Automatic failover when a Node fails keeps core services running.
- Load Balancing: Tasks are allocated according to Node resources to prevent overloading a single machine.
- Disaster Recovery: Multiple backup copies reduce data loss and downtime.
Key New Admin Console Capabilities
- Node Expansion: Add Nodes online without service interruption, with progress monitoring, retry on failure, rollback at reversible stages, and process log export.
- Requirement: The maximum number of devices allowed by the License must be greater than 20.
- Cluster Operations and Maintenance: Centrally view Cluster health, topology, and alerts in Cluster Overview, along with Node hardware information and CPU, memory, storage, and network load.
- Value-Added Services: Deploy and manage services such as 4G and Terra with one click, view deployment progress and health, and export process logs.
- License Management: Designate a Node within the Cluster or a remote Node for centralized License management.
- Restriction: Each Cluster supports only one Authorization Node, and all Licenses must be installed on that Node.
Key Compatibility Changes from Earlier Versions
- License Installation: DJI FlightHub 2, 4G, and Terra Licenses must be installed on the same Authorization Node. If your Licenses are installed on separate machines, contact after-sales support to migrate them before upgrading to V2.0.
- Upgrade Restrictions: Earlier versions cannot be upgraded to V2.0 through the visual interface, legacy command-line tools, or other previous methods. Follow this deployment manual carefully.
- Data Backup: Data backup commands and procedures have changed. Follow this deployment manual carefully.
- Routine Operations and Maintenance: All maintenance commands have been replaced, DJI FlightHub 2 service log export has changed, and the port list has been updated. Read this deployment manual thoroughly.
- Feature Adjustments: Remote operations and maintenance, login page customization, and alert rule modification are temporarily unavailable.
3. Live Streaming Engine Refactoring
- A new in-house live streaming media engine rebuilds the live streaming experience from the ground up, increasing single-machine live streaming concurrency to 2.8 times its previous capacity while further reducing CPU usage.
- Improved GB-28181 and RTMP protocol compatibility makes integration with general-purpose video surveillance platforms such as Hikvision easier.
- Dynamic scaling eliminates software throughput bottlenecks; concurrency capacity depends on network interface bandwidth.
4. Operations and Maintenance Experience Improvements
- Smaller Installation Package: The package size has been reduced to within 50GB.
- Improved License Tolerance: The original License remains valid when replacing the hard drive or network interface card, or reinstalling the operating system on the same machine. No License reissue is required, reducing service interruptions caused by routine maintenance.
- Improved Expiration Reminders: Upgrade License expiration and trial License expiration are distinguished, with more accurate explanations of their impact. Device limit alerts are less frequent, reducing repeated reminders.
5. MQTT Bridge API Authentication Support
Local MQTT operations, including registration and modification, require x-user-token for API authentication to prevent unauthorized users from changing MQTT configurations. You can enable authentication on the "DJI FlightHub 2 - Organization Settings - FlightHub Sync - MQTT" page.
6. O4 Ground Station Device Count Logic Improvements
When an O4 Ground Station is in "Gateway Mode - Roaming Base Station Mode," it no longer counts toward the licensed online device limit.
⚠️ Special Notes
The release of the all-in-one version has been postponed until next week.
II. Public Cloud Feature Alignment (Aligned to 2026-09-01)
1. Intelligent Search Supports Target Counts and Conditional Alerts
- "Cockpit - Multi-Modal Intelligent Search," "Mission Library - Multi-Modal Configuration," and "Analyzer - Intelligent Search": Search results now display target counts. Count-based alert thresholds can be set in prompts so that alerts are triggered only when the conditions are met. Combined searches for multiple targets are also supported.
- "Flight Records" and "Analyzer": Intelligent Search alert results support manually editing AI search targets, as well as manually adding and deleting targets.
2. Automation Workflow Improvements
- Periodic Workflow now includes VLM Intelligent Search and Change Detection Pro submodules, allowing AI analysis tasks to be configured directly within the workflow.
- Triggered Workflow now includes a Search in Place action. Combined with the Intelligent Recognition action, it can search for specified targets after the aircraft reaches the target location.
- The workflow list now includes Notification / AI tags. Execution logs support viewing the trigger method and notification results.
3. Change Detection Pro Support
- After deploying a VLM vision-language model, you can use Change Detection Pro with the same capabilities as the public cloud version.
4. Analyzer Supports Intelligent Search
- A large model can automatically identify target information, which can be manually converted into annotations mapped onto the model to generate an operation report.
5. Additional Feature Support
- The waypoint route editor supports setting an altitude (AGL) alert threshold.
- The Analyzer model timeline supports filtering by model type.
- Third-party developers and users who need to integrate DJI FlightHub 2 into existing systems can now refer to DJI FlightHub 2 Integration Skill to accelerate integration or explore potential solutions.
- Multi-Modal Recognition in Cockpit and Intelligent Search in Analyzer now support back-calculating geographic coordinates for up to 10 targets. These coordinates are for reference only.
- The map now supports creating spatial lines and spatial polygons. Once drawn, they can be viewed on the map and in Cockpit AR projections.
- Live stream sharing links now remember the page layout.
- OpenAPI V2.0 Sample Source Code Released: After deploying and successfully running the sample source code, you can explore the feature interface developed using OpenAPI V2.0. This helps you quickly understand OpenAPI integration and usage, accelerating secondary development and integration. For details, refer to the On-Premises OpenAPI V2.0 Manual.
⚠️ Special Notes
- Copilot-related features are not yet supported.
- Live streaming from DJI consumer drones and handheld devices is not yet supported.
This Release Fixes Known Issues in V1.7.0
Fixed Intermittent Device Offline Issue After Cloud Connection
- Fixed a memory issue in the V1.7.0 authorization service that caused all devices to intermittently go offline after connecting to the cloud.
Removed MQTT Bridge Internal Network Restriction
- Removed the internal IP restriction on MQTT Bridge introduced in V1.7.0, preventing existing configurations from becoming unavailable.
Fixed Cockpit Component Return-to-Home Failure
Fixed Missing Screenshots in 3D Gaussian Splatting Reconstruction Reports
Removed es-one-api Container to Reduce Redundant Services
Public Cloud Feature Alignment (Aligned to 2026-06-30)
Automation – Triggered Workflow Optimization
- Triggered workflows now support selecting DJI Dock 2 as the flight device.
- A new multi-modal recognition action has been added, enabling multi-modal recognition during flight or upon reaching a specified location.
- Custom dispatch delay time is now supported; you can choose to dispatch immediately (0 seconds) after an alarm is triggered.
- Supports one-click export of alarm points to a project annotation folder from the dispatch log, facilitating hotspot analysis of alarm areas.
- EventApi now includes dispatch workflow information synchronization, allowing alarm process and result information to be pushed to third-party systems.
- A new "False Alarm" tag has been added; you can mark the current alarm task as a false alarm within the cockpit and view it in the dispatch log.
Flight Records Support Video File Viewing
- Video file time track added: video files captured by payloads can be reviewed on the flight record timeline.
- Flight record toolbar optimized: supports viewing all media files generated during a flight mission in the media records section.
Cockpit and Mission Library Support O4 Ground Station
The cockpit and mission library now support adding the "O4 Ground Station" as a signal enhancement device. All standard missions support selecting a nearby available base station for connection, extending the single-flight operation range.
- Known Issue: After the cockpit or flight mission ends, the dock and ground station may not properly decouple, causing the cockpit icon to turn gray and preventing the device from taking off again.
- Temporary Workaround: Remotely restart the affected device via FlightHub to restore normal operation. This issue will be fixed in a future firmware update.
V1.7 Incremental Upgrade Package Released
This version provides an incremental installation package, enabling rapid upgrade of existing environments from V1.6 to V1.7 via incremental upgrade. Compared to full upgrades, incremental upgrades only update the necessary services that have changed, significantly reducing upgrade time and downtime.
- Incremental upgrades only support adjacent version upgrades (e.g., 1.6.n → 1.7.n); upgrading across multiple versions requires a full upgrade.
- Average incremental upgrade time is approximately 20 minutes.
- Incremental upgrade package download: Developer Website > Private Deployment Services > FlightHub 2 On-Premises > Console > History.
- Refer to the Upgrading FlightHub 2 On-Premises chapter in this deployment manual for details.
By deploying and running the sample source code, you can experience the feature interface developed based on OpenAPI V2.0. This helps you quickly understand how to integrate and use the OpenAPI, accelerating secondary development and integration. For details, refer to: On-Premises OpenAPI V2.0 Manual.
Version Number Display Optimization
To help customers accurately identify the current on-premises version, this release standardizes the version number display rules. After upgrading, the FlightHub organization management page and admin console will uniformly display the standard version number, e.g., V1.7.0.
Admin Console Configuration Effectiveness Optimization
When modifying configurations, the time required for services to take effect and recover has been reduced.
Deployment Capability Optimization
Fixed and optimized a series of common deployment issues, improving the success rate of FlightHub deployment and upgrades.
Visual Upgrade Optimization
Fixed a series of upgrade issues, optimized the technical architecture of the upgrade capability, and improved stability and extensibility.
Developer Console "History" Optimization
The "History" section now provides clearer access to installation package information for both the on-premises version and the all-in-one machine.
Deployment Manual Converted to Online Documentation
Now supports online viewing, searching, and PDF download.
Discontinuation of FlightHub V1.5 and Earlier Installation Packages
For product security and stability reasons, installation packages for FlightHub V1.5 and earlier versions will be discontinued. If you still need them, please contact your local industry application partner or DJI technical support for assistance.
New O4 Ground Station Support
- DJI FlightHub 2 now fully supports the "O4 Ground Station," enabling device management of cloud-connected O4 Ground Stations within DJI FlightHub 2.
- The cockpit and mission library now include the "O4 Ground Station" as a signal enhancement device. All standard missions support selecting a nearby available base station for connection, extending the single-flight operation range.
- ONVIF and GB/T 28181 standard protocol network cameras connected via the "O4 Ground Station" can be viewed and remotely controlled on FlightHub 2.
- RID and ADS-B airspace broadcast receivers connected via the "O4 Ground Station" support viewing detected aircraft on FlightHub 2, with one-click dispatch for handling abnormal situations.
Analyzer Supports Defect Annotation
- The analyzer supports defect annotation; annotations on media files precisely correspond to spatial positions on the sandbox model within the analyzer.
- Within the analyzer, clicking any position on the sandbox model automatically recommends related photos that may have captured that point.
- The spatial mapping relationship between 2D media and 3D models has been comprehensively improved!
True Altitude Recording and Alerts
- Supports enabling true altitude (AGL) alerts within the cockpit; an alert can be triggered when the altitude exceeds the set value.
- Flight records support calculating and displaying changes in AGL altitude during flight. Note: This altitude is calculated based on the FlightHub 2 global elevation model and may contain errors.
Live Stream Sharing 2.0 Supports Sharing Multiple Devices at Once
- The live stream sharing feature has been fully upgraded, supporting the addition of multiple device live streams in a single share link.
Automation Workflows Add Trigger and Notification Module Configuration
- Automated workflows now support configuring triggers and notifications, enabling more flexible workflow triggering and external status notifications.
⚠️ Special Notes
II. On-Premises Feature Improvements
Security Issue Fixes
- Fixed common security issues present in previous versions. To ensure system security and stability, upgrading to the current version is strongly recommended.
OpenAPI V2.0 On-Premises Version Released
- Building on the capabilities already available in V1.0, this version focuses on closing the loop for secondary development scenarios. It systematically completes APIs for key modules including device management, flight mission management, and data management (media, models, maps), with over 300 interfaces (V1.0 had 67).
- Additionally, this version optimizes the interface system by separating public cloud and private cloud API documentation, making interface classification clearer and easier for developers to understand and integrate, and enabling a more agile iteration pace for OpenAPI going forward.
Visual Deployment Tool Optimization
- Anomaly detection now includes "subnet conflict" detection, helping identify network configuration issues in advance.
- Supports launching the tool without an installed license.
- Optimized deployment workflows and exception handling mechanisms, fixed some known issues, and improved overall deployment success rate.
Live Streaming Performance and Stability Improvements
- Multi-core configuration is now supported. With sufficient CPU resources, live streaming concurrency can be increased up to 3x the original capacity.
- Fixed a series of issues such as live stream failures, forwarding push failures, black screens, and abnormal latency data, improving live streaming service stability.
Partial Error Messages and Interaction Optimizations in Admin Console
I. Public Cloud Feature Alignment (Aligned to 2026-04-15)
Ultra-Clear Panorama
- DJI Dock 3 and Matrice 4 Enterprise now support 500-megapixel ultra-clear panoramas, enabling efficient one-click environmental information capture.
- The cockpit and waypoint missions support setting 3X zoom spherical panorama shooting, with automatic stitching after capture; ultra-clear results can be viewed in the media library and support importing into the analyzer for timeline and other related features.
Resource Library Full Upgrade
- The original media library, model library, and design files have been merged into the "Resource Library" for unified and more convenient management.
- A recycle bin feature has been added; deleted files will first be moved to the recycle bin, with support for setting periodic automatic emptying to flexibly free up storage space.
Missions Support Multi-Modal Recognition
- The mission library supports enabling multi-modal recognition, which can identify specified targets during waypoint mission execution and notify users via a specified method upon detection.
Analyzer Adds Surface Area Measurement
- Supports rapid measurement of model surface area, facilitating coverage area calculation and cost estimation, significantly improving efficiency in engineering applications.
- Applicable to scenarios such as soil covering, lawn greening, and irregular curved surface buildings.
FlightHub Sync
- The FlightHub 2 cloud interconnection feature (Beta) has completed testing and validation; it will be gradually discontinued and upgraded to the new FlightHub Sync.
- File sync: Added support for cross-configuration of file type–project–storage bucket, supporting simultaneous configuration of multiple storage buckets.
- Telemetry data sync: Added telemetry data sync, enabling real-time synchronization of drone attitude data to third-party platforms.
- Live stream forwarding: Added RTSP protocol support.
- Added Event API support; configurable event rules allow pushing specific FlightHub events to external systems.
- File sync supports automatic deletion of source files in FlightHub after synchronization is complete.
- Third-party airspace data management: Supports configuring airspace information from third-party airspace data providers and unified display within FlightHub.
FlightHub Modeling API
- OpenAPI adds the FlightHub Modeling API, supporting rapid integration of cloud-based modeling capabilities by third-party systems.
Gaussian Splatting
- Edge-side reconstruction now supports Gaussian Splatting format, providing more realistic and clear results for scenes with fine structures and glass curtain walls.
Model Sharing
- The model sharing page supports viewing via phone or tablet QR code scan without logging in.
Annotations Synced to Analyzer
- The analyzer map settings support synchronized display of project annotations, and support selecting annotations for one-click conversion to measurements.
AirSense Supports ICAO Filtering
- The "Map Operation Area" on the team page has been upgraded to "Airspace Safety," adding AirSense alert management with ICAO number filtering support.
AI Change Detection
- Media change detection: The media library supports intelligent detection between two groups of media folders from the same waypoint mission, marking changed areas.
- Model change detection: The model library supports intelligent detection between two 2D models with overlapping areas, marking changed areas.
GCP Modeling
- Cloud reconstruction supports setting ground control points (GCPs); standard targets support automatic point marking and automatic reconstruction triggering.
Support for Real-Time Megaphone Device
- Supports initiating voice broadcasts and TTS broadcasts directly from the cloud.
⚠️ Special Notes
New Visual Deployment Capability
- Supports completing deployment of the FlightHub platform, Terra, and 4G services in an on-premises environment through a visual interface, replacing traditional command-line and manual configuration methods.
- Helps customers shorten the deployment cycle, lower the implementation threshold, and improve deployment success rates. Suitable for first-time deployments, initial implementations, or O&M scenarios aiming to reduce deployment complexity.
New Incremental Upgrade Capability
- Starting from this version, incremental upgrade capability is supported. Compared to previous full upgrades, only the necessary services that have changed need to be upgraded for adjacent version upgrades, significantly reducing upgrade time and downtime.
- Note: This capability will officially apply after the next version is released. Customers must first upgrade to this version before being able to use incremental upgrades when upgrading to the next adjacent higher version.
Support for True Data Deletion
- Starting from this version, performing delete operations on FlightHub media library, model library, and design files will result in permanent deletion, with corresponding storage space released simultaneously.
AIO Admin Console Adds Many Visual Configuration Items
- Operations previously relying on code, scripts, or manual configuration file edits can now be performed through the AIO admin console's visual configuration interface, reducing O&M learning costs and implementation costs while improving daily configuration management efficiency.
- Starting from this version, the AIO admin console will be deployed to the on-premises environment alongside FlightHub by default.
AIO Admin Console Series of Experience Improvements
- Added FlightHub version number display.
- Map management supports configuring layer information.
- Supports one-click HTTPS certificate acquisition.
- Remote O&M interaction optimized.
- Log export supports selecting a time range.
Automation Supports Auto-Dispatch Workflows
- Auto-dispatch workflows can be created within automation workflows; dispatch can be triggered by external systems or manually on the map, and the aircraft will automatically execute preset actions upon reaching the specified coordinates.
AI Mission Optimization
- Supports selecting a 3x or 7x zoom lens for mission planning within patrol missions.
- Algorithm selection now supports both DJI official and third-party infrared target recognition algorithms.
- Alarm actions now support megaphone and spotlight actions.
Virtual Cockpit Supports Real-Time AI Alert Configuration
- During live flight, onboard official and third-party algorithms support setting alert thresholds; alerts triggered by the threshold will be collected in the alert list.
Historical Elevation
- The analyzer supports creating point measurements and historical elevation measurements; draw points on the map to obtain the geographic location and surface height of historical models.
Analyzer Supports Sharing
- The analyzer sharing page allows direct viewing via phone or tablet QR code scan without logging in, including model media timeline, measurement results, and analysis reports.
New Zenmuse L3 Payload Support
- Supports planning L3 payload missions related to Matrice 400 Enterprise drones.
- Area missions support displaying L3 payload point cloud operation result estimation reports, enabling pre-assessment of output quality.
- Supports displaying L3 point cloud files uploaded from the Pilot 2 App.
Support for Airspace Management Provider Flight Data Reporting
- This feature can be enabled in Organization Settings > Organization Data Management > Airspace Management Provider Flight Data Reporting. After entering the address and token provided by a third-party provider, flight data can be pushed to that provider in real time.
Model Supports Altitude Calibration
- The analyzer supports setting altitude calibration points. All models in the analyzer will adjust the model surface height at that location to the target altitude, applying to measurement calculations.
[Feature Optimizations]
- Onboard algorithms support target segmentation algorithms.
- Automated workflows support selecting to continue executing remaining nodes after closure.
- The analyzer supports following the organization's imperial unit settings.
- Analyzer volume measurements support setting expansion coefficients.
- "DJI Dock 3" vehicle-mounted mode supports custom network RTK calibration.
- "DJI Dock 3" supports one-click clearing of aircraft unlock certificates.
- Added support for Japanese, Korean, German, and French.
- Supports annotation list filtering to display required annotation information based on personal needs.
- Slope calculation and triangulation tools optimized to support dynamic calculation following the model surface.
On-Premises O&M Capability Optimization
- Added adaptive networking capability; when the dock/handheld aircraft/FlightHub are on different network segments, the service layer will adaptively forward. This takes effect by setting
MULTIPLE_IP_ENABLEtoTrueinENV. - Added a backend visual interface for visual O&M management of the on-premises version; accessible at:
{Server IP}:30888. - Bypass stream forwarding lifts the single-machine 20-channel limit; forwarding channels can be freely configured according to server specifications.
Virtual Cockpit Interface Fully Refreshed
- Interface refresh: A comprehensive visual and interaction overhaul has been applied to the virtual cockpit interface.
- Flexible layout: More layout options are now supported, allowing users to adjust flexibly based on their needs.
- Icon updates: All interface icons have been replaced with new designs that are more refined, attractive, and easy to recognize.
- Interaction optimization: The overall user interaction logic has been optimized; the operation flow is more intuitive and the user experience is smoother and more efficient.
Virtual Cockpit Supports Multi-Aircraft Control
- The virtual cockpit adds a multi-aircraft control list, supporting the addition of collaborative aircraft.
- Supports quick aircraft switching, enabling one person to control multiple aircraft simultaneously.
Spatial Line/Area AR Projection
- AR projection in the virtual cockpit adds marker line and marker area categories.
- Supports displaying spatial lines and areas drawn and synced by Pilot in the live stream view.
Overview Dashboard
- A new overview dashboard feature provides a centralized entry point for data viewing, helping users efficiently grasp key information.
- The dashboard precisely matches the data viewing needs of management roles.
- The overview dashboard can display core data including organizational assets, device mission scheduling, and operation results, comprehensively covering the information dimensions needed for management decisions.
Media Intelligent Search
- New intelligent search capability precisely identifies and annotates targets in media, improving content retrieval and marking efficiency.
- Supports exporting target search results as reports for data retention, sharing, and subsequent analysis.
- Organization administrators can view organizational data at the organization level and quickly copy annotations, missions, models, and no-fly zone files between different projects.
Waypoint Missions Support Batch Editing
- In the mission editor, waypoint missions support batch modification of mission parameters and actions.
Message Box
- Optimized and aggregated FlightHub message notifications into the message box; view historical system message notifications and configure message alert types in the personal center.
Support for Mavic 3T Advanced Enterprise Drone
- Supports remote control of the Mavic 3T Advanced Enterprise drone's gimbal camera.
- Supports remote control of Mavic 3T Advanced Enterprise drone PSDK accessories.
- Supports point, line, and area planning for the Mavic 3T Advanced Enterprise drone.
Manifold 3 Cloud Adaptation
- Manifold 3 supports cloud-based remote application management and invocation.
- Device management: Device recognition display and application management for Manifold 3.
- Virtual cockpit: Loaded applications can be invoked with real-time display of application effects.
Third-Party Onboard AI Algorithm Adaptation
- The virtual cockpit adds third-party infrared AI recognition algorithms.
- Supports displaying AI recognition results in real time under infrared lenses.
- Waypoint mission intelligent recognition actions and patrol missions support selecting third-party onboard AI algorithms as recognition algorithms.
AI Operation Report Export
- Flight records add AI alert record operation report export functionality.
Multi-Modal AI Target Detection
- The virtual cockpit adds multi-modal target detection functionality.
- Supports users configuring alert targets via text, image, or real-time bounding box selection.
- Alert snapshots are automatically archived to a dedicated folder in the media library, with tag filtering support.
- Supports setting alert notification categories and alert recording intervals.
AI Alert Record List
- The AI alert record list style in the virtual cockpit and flight records has been fully refreshed.
- Supports archiving and displaying multi-modal target detection and cloud AI algorithms.
AR Street Projection
- The virtual cockpit adds AR street projection functionality.
- Supports adjusting opacity, height offset, and landmark display parameters.
Measurement Calculations
- Create measurements and calculation tools in the analyzer based on models and design files for line measurement and volume measurement.
- Line measurement: Supports triangulation of line segments, slope calculation, and extraction of longitudinal/cross sections.
- Volume measurement: Supports current model volume calculation and two-period/multi-period model volume change calculation.
Timeline
- Supports viewing the model timeline for quick dynamic switching to display model evolution, intuitively tracking project progress.
- Supports viewing the media timeline with time-dimension and spatial-dimension correlation viewing, enabling visual traceability and management of processes.
Analysis Reports
- Supports generating measurement analysis reports with configurable report covers, measurement areas, and other structured content.
- Supports report templates, scheduled automatic report generation, and email sending for tracking progress, data archiving, and reporting.
Automated Workflows
- Full-process integration: Supports a fully automated workflow of "Flight Capture → Model Reconstruction → Measurement Calculation → Analysis Report," achieving automation from data collection to intelligent analysis.
- Flexible task management: Freely select existing tasks or create new ones, with support for editing and association to meet different scenario needs.
- Efficient preview and execution: One-click preview of task execution results, quick save and enable automation to improve operational efficiency.
Design File Support
- Supports PDF and DXF files; design files can be displayed at the correct position on the map via coordinate system conversion or sync point calibration.
- Supports parsing DXF 3D Face to obtain design heights, enabling calculation of longitudinal/cross sections and volume measurements.
Engineering Coordinate System
- The project settings page supports setting engineering coordinate systems.
- Supports EPSG universal coordinate systems and custom projection coordinate systems.
- Supports four-parameter and seven-parameter calculation and application.
[More Feature Support]
- Supports customizing the collision risk threshold for manned aircraft, effective only for dock aircraft.
- Supports customizing the return-to-home reserved battery level for dock aircraft; in windy conditions, it is recommended to increase this value appropriately to ensure flight safety.
- The virtual cockpit supports infrared photo format settings.
- Added Spanish language support.
On-Premises Deployment Optimization
- Added an AI large model deployment guide; viewable in the latest on-premises deployment guide.
- Added an AR street projection map deployment guide; viewable in the latest on-premises deployment guide.
New On-Premises Capabilities
- Rapid modeling: Supports enabling rapid modeling when issuing mapping-type missions; real-time thumbnails are transmitted via air to quickly output models for emergency scenarios.
- Message notification: On-premises version in-app messages support email notifications.
- Storage display: The current storage usage of each resource can be viewed in the organization management interface.
DJI FlightHub 2 On-Premises V1.2 features are fully aligned with DJI FlightHub 2 public cloud version.
FlightHub Sync
- FlightHub Cloud Interconnection Beta has been fully upgraded to FlightHub Sync, enabling synchronization of media, missions, flight records, and other information from specified projects to external storage buckets.
AI Capability Support
- Added patrol missions: specify areas combined with intelligent recognition algorithms to automatically identify people, vehicles, and boats in patrol areas and send alert notifications.
- Virtual cockpit supports real-time AI recognition and automatic alerts for people, vehicles, boats, and moving targets based on infrared streams.
- FlightHub media library supports display, viewing, and sharing of onboard AI video, with AI recognition results visible during viewing and sharing.
Remote Control Capability Support
- Supports remote control of Matrice 4D series aircraft connected via remote controller.
- Supports one-click issuance of return-to-home commands to all aircraft in a project.
Onboard Algorithm Management
- Supports loading third-party onboard algorithms distributed from the developer website onto aircraft connected to docks, via the "Algorithm Management" page.
- Flight records add Dock 2 support.
- Detects obstacle avoidance history records when issuing missions; if present, a prompt is shown. If obstacle avoidance is triggered during repeated or continuous missions, subsequent missions are automatically suspended and require manual release to ensure safety.
- Added automatic association of abnormal feedback with dock/aircraft logs; data is automatically matched after selecting a time. Supports filling in error code fields to improve issue analysis efficiency.
- Supports remote switching of the FlightHub public/private environment for the dock.
- Supports 2D real-time mapping (requires deployment of the mapping service).
- Optimized the on-premises incremental package upgrade process with visual upgrade inspection and installation steps.
- On-premises O&M features upgraded: supports server health checks and built-in NTP service.
III. Bug Fixes
- Known issue fixes to improve system stability.
Firmware Versions
For firmware version support details, visit the DJI Developer website deployment manual, or directly download the Latest Firmware List.
I. Expanded Drone and Dock Device Support
New Model Support
- Matrice 300 RTK, Matrice 350 RTK Enterprise drones: Supports viewing flight footage and payload live streams on FlightHub 2.
- Mavic 3 Enterprise drone: Supports remote control of the gimbal camera.
- Matrice 4 Enterprise drone: Supports remote control of the aircraft and gimbal camera, with AI recognition (people, vehicles, boats).
- DJI Dock 3: Supports AI recognition (people, vehicles, boats), intelligent tracking, AI missions, vehicle-mounted deployment mode, and multi-aircraft safe takeoff and landing.
New Accessory Support
- D-RTK3 relay station.
- DJI AS1 megaphone.
- DJI AL1 spotlight.
New Payload Support
- Zenmuse H30, Zenmuse H30T.
- Zenmuse H20, Zenmuse H20T, Zenmuse H20N.
II. Mission Feature Upgrades
Mission Planning
- Standard geometric shape missions.
- Oblique facade missions.
- Close-range photogrammetry missions: Supports generating fine modeling missions (Matrice 4 supported).
- Area mission orthophoto capture: Supports enabling orthophoto interval shooting in area missions to improve execution efficiency (Matrice 4 supported).
- Waypoint missions: Added panoramic photo action; supports swapping start and end points of waypoint missions, with option to switch some persistent actions; when adding a video recording action, supports synchronously recording the virtual aircraft and camera pose information, automatically adding aircraft yaw angle, gimbal yaw angle, gimbal pitch angle, and camera zoom actions.
Mission Management
- Mission folders: Supports creating multi-level folders for managing mission files.
- Batch download: Supports batch downloading of missions from the mission library.
Mission Operations
- PPK file upload: Base station PPK files from mission tasks are uploaded and stored in the corresponding mission task folder in the media library.
III. Full AI Feature Support
AI Recognition and Intelligent Tracking
- The virtual cockpit supports real-time AI recognition and automatic alerts for people, vehicles, and boats, with instant viewing of alert record details triggered during mission execution (Matrice 4, DJI Dock 3 supported).
- Third-party algorithm models developed on the DJI AI platform support import and application via Pilot 2, expanding AI recognition scenarios.
- The media library supports display, counting, and editing of AI recognition results; currently only wide-angle and zoom photos are supported.
AI Missions (DJI Dock 3 supported)
- Waypoint missions support intelligent recognition actions, enabling recognition of people, vehicles, boats, and temperature-exceeding targets during missions; after an alert, supports point-by-point photo capture, video recording, and wait-for-takeover actions.
- The virtual cockpit supports intelligent tracking; continuous tracking begins once an AI-recognized target is selected (DJI Dock 3 supported).
IV. Dock Feature Improvements
Flight Operation Capability
- DJI Dock 1 supports mission cancellation upon RTK convergence timeout.
- DJI Dock 2 supports emergency landing.
- DJI Dock 3:
- Supports multi-aircraft safe takeoff and landing; in dense deployment scenarios, devices within a project have safe scheduling capability during takeoff and landing phases.
- Supports approach/departure routes; aircraft execute approach/departure routes before operations.
- Supports custom no-landing zones; aircraft cannot automatically land within no-landing zones.
- Supports vehicle-mounted deployment mode, enabling quick device position calibration and pre-takeoff safety check capabilities.
- First-person view tracking capability upgraded for smoother aircraft FPV operation.
Payload Operation Capability
- DJI Dock 2 supports manual mode with shutter, ISO, aperture settings, timed shooting, storage settings, video resolution settings, and linked zoom functions.
- DJI Matrice 3D adds distortion correction toggle and mechanical shutter functions.
[Other Feature Support]
- AR projection: DJI Dock 2 supports viewing annotation points directly in the live stream view.
- Auxiliary imagery: DJI Dock 2 supports viewing auxiliary imagery.
- Stealth mode: Added stealth mode (DJI Dock 2, DJI Dock 3 supported).
- Remaining operation time: DJI Dock 2 virtual cockpit adds remaining operation time display for aircraft.
- Video embedded SRT: Supports embedding SRT files in video and downloading.
- Auxiliary marking: DJI Dock 2 supports simulated point marking via camera auxiliary heading (terrain data loading required).
V. Software Feature Upgrades
New Multi-Stream Live View
- Multiple devices within a project (dock live stream, aircraft gimbal camera) can be viewed simultaneously, supporting 1/4/9/16 grid layouts with device map location and other auxiliary features.
Task Management Capability Upgrades
- Supports subscribing to abnormal notification messages for dock covers left open for an extended period.
- Supports creating abnormal feedback from the mission library and alert list, with support for viewing abnormal feedback analysis results.
Map Feature Improvements
- Map annotations support creating multi-level folders.
- Map annotations add circular annotation tool.
- The map search box can search for: geographic locations, map annotations, device information, and models and photos already loaded on the map.
- Optimized the re-centering experience for various elements on the map.
- Supports syncing observation records of aircraft cameras recorded by Pilot 2 to FlightHub 2 (Matrice 4 supported).
- Supports syncing spatial points, lines, and areas generated by Pilot 2 to FlightHub 2 (Matrice 4 supported).
Media Feature Upgrades
- Supports importing local media resources such as photos, panoramas, stream screenshots, videos, and PPK files into FlightHub.
- Added graffiti quick operation tips with support for modifying graffiti annotation colors.
- Supports filtering undescribed graffiti photos by "Unnamed" tag.
Model Reconstruction Upgrades
- Model reconstruction supports close-range photogrammetry coarse model format, enabling generation of coarse models for close-range photogrammetry missions.
- Model reconstruction supports resolution selection.
Cloud Interconnection Upgrades
- Supports obtaining PPK/SRT files via cloud-to-cloud connection.
- Supports issuing mission tasks via cloud-to-cloud connection.
OpenAPI
- Authentication and authorization.
- System services.
- Organization projects.
- Device management.
- Live stream management.
- Mission management.
- Task management.
- Model management.
- Annotation management.
Frontend Components
- Supports mission creation component, mission editor component, cockpit component, and project/map component; also supports custom theme colors and custom styles for components.
MQTT Bridge
- Provides MQTT bridging and forwarding functionality, supporting forwarding dock MQTT messages to third-party systems via FlightHub 2.
VI. Bug Fixes
Firmware Versions
| Product | Firmware Version |
| Matrice 350 RTK | 10.01.08.05 |
| Matrice 300 RTK | 60.01.08.06 |
| Matrice 30/30T | 10.01.05.04 |
| DJI RC Plus | 05.02.13.02 |
| Mavic 3 Enterprise Series | 10.01.05.03 |
| DJI RC Pro Enterprise | 02.01.05.10 |
| Matrice 4 Series | 12.00.01.07 |
| DJI RC Plus 2 | 01.61.03.03 |
| DJI Dock 3 | 99.99.92.50 |
| DJI Dock 2 | 10.01.32.05 |
| DJI Dock | 10.01.02.05 |
| DJI Pilot 2 | 99.0.0.1 |
After successfully deploying FlightHub 2 On-Premises, most features are consistent with the FlightHub 2 public cloud experience. The main new and optimized features are as follows:
Basic Features
- Supports Docker-based rapid deployment; refer to the DJI FlightHub 2 On-Premises Deployment Manual.
- After deployment, the default access mode is pure IP access; no DNS configuration is required (can be enabled later).
- Supports offline map data import and configuration, including road network data import and display.
- Supports offline no-fly zone display.
- Supports binding docks with Pilot, with the option to select "FlightHub 2 On-Premises" during binding.
- Supports offline firmware upgrade and management.
- Supports quick navigation to the on-premises manual (press the question mark key on any interface to navigate).
- Supports local account system and OAuth2 account system (choose one).
- Supports basic device and cloud service log retrieval.
- Supports license expiration reminder.
Signature Features
- Supports private deployment of 2D/3D modeling services.
- Supports customized login page modification, including Logo, background, and other information.
- Cloud interconnection supports GB28181 format streaming.
- The cloud interconnection module supports mission task issuance, allowing third-party cloud systems to call interfaces to directly issue "execute immediately" type mission tasks.
- After successfully deploying FlightHub 2 On-Premises, the FlightHub 2 On-Premises O&M platform is included by default, enabling more intuitive monitoring of the FlightHub private deployment business operations. Real-time system status monitoring is also possible by adding Webhook callbacks for monitoring messages.
Firmware Versions
| Matrice 3D/3TD | 10.01.1607 |
| DJI RC Pro Enterprise | 02.01.0507 |
| DJI Dock 2 | 10.01.1607 |
| Matrice 30/30T | 10.01.0014 |
| DJI RC Plus | 05.02.1106 |
| DJI Dock | 10.01.0205 |
| DJI Pilot 2 | 10.1.0.30 |
Known Issues
| Affected Products | Issue Description | Workaround |
| All models | Clicking the device window button to watch a live stream causes the cockpit live view to freeze for approximately 0.5 seconds before recovering | - |
