AR Street Map Deployment
This section explains how to obtain AR street map data and update the map configuration from the command line.
Data Acquisition
Go to MapTiler and download the map file for the region shown in the illustration.
Data Publishing - Command-Line Operation
On the server, follow these steps to view and update the map configuration:
  1. View the current map configuration:
    k3s kubectl get cm es-management-mapconfig -n flighthub2 \
      -o jsonpath='{.data.map_config\.yaml}'
  2. Prepare a new configuration file based on the current configuration. Then run the following commands to update the configuration and restart the service so that the changes take effect:
    # ① 用新配置文件覆盖更新,将 /path/to/new_map_config.yaml 替换为真实文件路径
    k3s kubectl patch cm es-management-mapconfig -n flighthub2 --type merge \
      -p "$(jq -Rs '{data: {"map_config.yaml": .}}' /path/to/new_map_config.yaml)"
    # ② 重启服务,使新配置生效
    k3s kubectl rollout restart deploy/es-management -n flighthub2
    /path/to/new_map_config.yaml is the actual path to the new configuration file. Use the configuration output in step 1 as a starting point, edit it, and save the file. The ar_resource section configures AR map resources. An example configuration is shown below:
    map_resource:
        type: default
        street_link:
        link: http://47.98.53.122:30814/services/satellite-2017-11-01-china_shenzhen/tiles/{z}/{x}/{y}.jpg
        type: custom
        street_link: http://47.98.53.122:30814/services/street_osmtest_shenzhen_mbtiles_v3_level15/tiles/{z}/{x}/{y}.png
        min_z: 0
        max_z: 13
        type: custom
        street_link: https://mt1.google.com/vt/lyrs=h&x={x}&y={y}&z={z}&hl=zh-CN
        link: https://mt1.google.com/vt/lyrs=s&x={x}&y={y}&z={z}&hl=zh-CN
    ar_resource:
        type: custom
        min_z: 0
        max_z: 14
        link: https://${SERVICE_DOMAIN}:${MAP_SERVER_TCP_PORT}/services/{mbtiles_file_name}/tiles/{z}/{x}/{y}.pbf
Note:
  • link concatenation rule: If the mbtiles file is named osm-2020-02-10-v3.11_china_shenzhen.mbtiles, the resulting path is:
${SERVICE_DOMAIN}:${MAP_SERVER_TCP_PORT}/services/osm-2020-02-10-v3.11_china_shenzhen/tiles/{z}/{x}/{y}.pbf
Attention: The map data downloaded from MapTiler in this section is an MBTiles file, with tiles in PBF format.
