If a Certificate Read Error or Import Error Occurs, How to Completely Uninstall All Licenses on This Machine?
If you encounter certificate-related issues, you should first consult your vendor on how to handle them. If it is already clear that the license needs to be deleted, you can perform the following operations:
Operation Process
- First, check the list of installed licenses:
cmu -I
- Delete the license
cmu --del -S {license serial number}
