Network Configuration for the On-Premises DJI Enterprise App
When using the on-premises DJI Enterprise app, the mobile device must be able to access the on-premises service address. To connect through a carrier's dedicated 4G network, use a SIM card provisioned for that network and configure the APN (Access Point Name) as required by the carrier.
Before Configuration
Confirm the following information with your carrier or enterprise network administrator:
Configuration ItemDescription
Dedicated-network SIM cardThe dedicated APN service must be activated, and the SIM card must be compatible with the device or 4G adapter. Regular public-network SIM cards generally cannot use a dedicated APN directly.
APNThe dedicated-network access point name provided by the carrier.
Username, password, and authentication methodEnter these as required by the carrier. If not required, leave them blank or use the defaults.
IP protocolSelect IPv4, IPv6, or IPv4/IPv6 as required by the dedicated network.
Service address and network connectivityEnsure that the dedicated network can reach the network hosting the on-premises services and that the required ports are open. If using a domain name, it must resolve correctly.
The following are general configuration steps. Menu names may vary by device, OS version, and carrier. Use the APN parameters provided by your carrier.
Switching APNs on Android
  1. Insert the dedicated-network SIM card, open Settings, and go to Mobile network or SIM cards and mobile data.
  2. Select the relevant SIM card and open Access Point Names (APN). On dual-SIM devices, also set this SIM as the default mobile data SIM.
  3. Create a new APN profile and enter its name, APN, and the username, password, authentication method, IP protocol, and other parameters provided by the carrier. You can choose a profile name, such as “Enterprise Network”; the APN must be entered exactly as provided.
  4. Save the profile and select that APN. Parameters such as MCC and MNC are normally detected automatically from the SIM card and do not need to be changed. Leave unspecified fields, such as proxy and port, at their defaults.
  5. Enable mobile data, turn off Wi-Fi, briefly turn airplane mode on and then off, and wait for the device to reconnect. Restart the device if necessary.
  6. Open the on-premises DJI Enterprise app, confirm that the service address is configured correctly, and verify that login and service access work normally.
To switch back to the public network, select the carrier's original public-network APN from the APN list and reconnect to the mobile network.
Switching APNs on iOS
  1. Insert or enable the dedicated-network SIM card. Go to Settings → Cellular, select the line used for the dedicated network, and set it as the cellular data line.
  2. Open Cellular Data Network and enter the carrier-provided APN, username, and password in the Cellular Data section. On some versions, this option is under Cellular Data Options.
  3. Return to the previous screen, turn off Wi-Fi, and turn cellular data off and back on. If necessary, briefly turn airplane mode on and then off, or restart the device.
  4. Open the on-premises DJI Enterprise app, confirm that the service address is configured correctly, and verify that login and service access work normally.
If Cellular Data Network is not displayed or the APN cannot be edited, the configuration may be controlled by carrier settings or device management policies. Contact your carrier or enterprise IT team to configure it using the carrier settings or configuration profile they provide. Managed devices can receive the configuration through MDM.
To switch back to the public network, restore the public-network APN as instructed by your carrier or enterprise IT team. Settings deployed through a configuration profile or MDM must be adjusted through the corresponding management method.
Configuring a Dedicated 4G Network Adapter
This section applies to USB 4G adapters, cellular communication modules, and 4G routers that support dedicated APN configuration. Refer to the device manual for the specific configuration interface.
  1. Install the SIM card and connect the device: Insert the dedicated-network SIM card as described in the device manual and connect the adapter to the terminal or router. If the USB adapter requires a driver, install it first. Confirm that the SIM card is recognized and the cellular signal is normal.
  2. Create a dedicated-network connection profile: In the adapter management tool, system dial-up settings, or router management page, find APN, Connection profile, or Dial-up settings. Enter the APN, authentication information, and IP protocol provided by the carrier. If the device automatically detects a public-network APN, switch to manual configuration.
  3. Enable the dedicated-network connection: Save the profile, set it as the active connection profile, and reconnect or restart the adapter. Confirm that it is connected and has obtained an IP address. IP addresses are generally assigned by the carrier. Even for fixed-IP services, follow the carrier's requirements rather than specifying an address yourself.
  4. Check routing and DNS: Ensure that traffic to the on-premises services passes through this adapter or router. If the terminal is also connected to Wi-Fi or a wired network, have the network administrator check route priorities. Dedicated-network domain names require a DNS server that can resolve them.
  5. Verify service access: Confirm that the terminal can reach the on-premises service address, then verify login and business functions in the app.
If the adapter is used with an enterprise terminal such as a remote controller, first confirm that the terminal supports the adapter model and dedicated APN configuration. If using on-premises 4G enhanced transmission, also complete the service deployment and device configuration described in 4G On-Premises Enhanced Transmission Service Deployment.
FAQ
SymptomTroubleshooting
Unable to connect after changing the APNCheck that the SIM card is provisioned for the dedicated network, the APN and authentication information are correct, and the signal and IP protocol settings are appropriate.
Connected to 4G, but the app cannot access the serviceCheck the app's service address, routing from the dedicated network to the server, DNS, and firewall ports. A 4G indicator does not guarantee access to on-premises services.
The service is accessible only after Wi-Fi is turned offCheck route priorities when multiple networks are connected, and ensure that traffic to the on-premises services uses the dedicated-network connection.
Unable to access the internet through the dedicated networkSome dedicated networks allow access only to internal enterprise resources. This is expected; refer to the scope of the provisioned network service.
