How Do I Obtain System Logs?
In the Admin Console, go to “FlightHub Management” → “Operations and Maintenance Settings” to download DJI FlightHub 2 operations and maintenance logs.
  • If DJI FlightHub 2 services encounter issues, provide these logs to DJI FlightHub 2 after-sales support to help troubleshoot.
Download operations and maintenance logs
Command-Line Procedure
Run the command flighthub2-installer cli log-download (supports filtering by type and date range and produces a compressed archive); (todo: What is the execution environment? For example, on which Node and in which directory should it be run? Is this the complete command?)
