Version Compatibility
2026-11-04Loading rating…
DJI Pilot Plugin runs on top of Pilot. The MSDK version used by the plugin determines which Pilot version it requires, and the Pilot version installed on the remote controller determines whether the plugin can connect and which open capabilities it can use. This page lists the current version pairing and explains what happens when the two do not match.
Version Pairing
MSDK VersionPilot VersionSupported Aircraft
5.20.119.0DJI Matrice 5T
Note:
  1. The Pilot version column lists major versions only; refer to the Pilot installed on the remote controller for the exact minor version.
  2. Supported aircraft refers to the aircraft supported by that MSDK version. This table is updated as new MSDK versions are released.
Version Compatibility and Upgrade Recommendations
Version CombinationCompatibilityUpgrade Recommendation
Plugin MSDK version equals Pilot versionFully matched; the plugin can use all capabilities available in that versionNo additional upgrade is required
Plugin MSDK version is lower than Pilot versionPilot is compatible with older plugins; the plugin runs normallyA Pilot upgrade usually does not require a corresponding plugin upgrade
Plugin MSDK version is higher than Pilot versionHigher-version interfaces used by the plugin are unavailableRecommend that users upgrade Pilot on the remote controller
To use capabilities from a newer version in your plugin, rebuild and release the plugin using the latest MSDK version.
See Plugin Link State for handling connection states and version error callbacks, and Quick Start for the full troubleshooting steps under "onRemoteServerCompatibleError is called".
