Competency Map
2026-11-03Loading rating…
The capabilities available to a DJI Pilot Plugin consist of two parts:
Capability sourceDescriptionUsage
MSDK native capabilitiesExisting MSDK capabilities such as Key operations, wayline missions, streaming, and MOPIdentical to native development; refer to the existing MSDK tutorials
Pilot Open capabilitiesNew interfaces added in plugin mode for interacting with Pilot's UI and platform servicesSee the two capability tables below on this page
Pilot Open capabilities fall into two categories by what they act on: UI capabilities and platform capabilities.
UI Capabilities
UI capabilities act directly on Pilot's UI, letting you present your own business content on top of Pilot's existing interface.
CapabilityInterfaceDescriptionTutorial
Custom UI ComponentsIRemoteViewPageManagerAdd custom layouts at designated positions on Pilot's UI, supporting buttons, text, images, input fields, lists, and moreCustom UI Components
DialogIRemoteDialogManagerPop up dialogs in Pilot's standard style, supporting five types: tip, confirm, input, single-choice, and multi-choiceDialog
Map widgetIMapWidgetManagerCreate, query, update, and delete annotations, layers, and map elements on Pilot's map, and listen for click eventsMap Widget
AR projectionIARManagerProject AR elements onto the video feed, supporting point, line, polygon, and circle typesAR Projection
Camera view drawingICameraViewDrawingManagerDraw boxes, polygons, and text overlays on the video feedCamera View Drawing
Page navigationINavigateManagerNavigate from the plugin to a designated page in PilotPage Navigation
Platform Capabilities
Platform capabilities target the data exchange and runtime support between the plugin and Pilot.
Plugin Connection StateIRemoteLinkManagerGet and listen for the connection state between the plugin and PilotPlugin Connection State
File transferIFileTransferManagerPush files between the plugin and Pilot, and query the file listFile Transfer
Pilot server configIRemoteServerConfigManagerGet and listen for Pilot's configuration, such as the system languageServer Config
Pilot ActionIRemoteControlManagerTrigger a designated action in Pilot, such as switching back to the main camera viewRemote Action
Local ModelingIPilotModelingManagerListen for the file state of real-time 3D modeling and export modeling filesLocal Modeling
Relationship with MSDK Native Capabilities
Plugin mode does not change how MSDK's native capabilities are used. The Key system, callbacks, error codes, and registration flow are identical to native development, and the MSDK code from your standalone app can be reused directly in a plugin.
Pilot Open capabilities are the increment unique to plugin mode: these interfaces depend on Pilot to run and cannot be called by a standalone app (SDKLinkMode.LOCAL).
Next Steps
  • Follow the Quick Start to create your first plugin project.
