Jetson Nano Quick Start
2023-09-19
No Rating
Introduction
The E-Port Developer Kit converts the aircraft's E-Port interface into various standard hardware interfaces, facilitating hardware device connection and SDK development debugging. For the list of aircraft models supported by the E-Port Developer Kit and their compatible interfaces, refer to the Standard Hardware Interface and Development Kit Tableopen in new window.
This guide is based on the M350 RTK aircraft, E-Port Developer Kit, and Jetson Nano Developer Kit, outlines the development steps, from hardware connection, software environment setup, development package obtaining, to compilation and execution. It aims to assist you in getting familiar with PSDK (Payload SDK) development. This example works for all aircraft models supported by PSDK.
Basic Information
Below are the hardware devices used in this tutorial. It's recommended to get yourself familiar with them before reading this tutorial:
Hardware Environment Setup
1. Necessary Hardware
Hardware ItemQuantityPurpose
NVIDIA Jetson Nano Developer Kit1PSDK Operating Platform
High-Definition Monitor (HDMI or DP) + HDMI or DP Cable1Display interface for Ubuntu system on the developer board
Keyboard + Mouse1Human-computer interaction for Ubuntu system on the developer board
Wireless Network Interface Controller/ Ethernet Cable1Internet access for the developer board
E-Port Developer Kit1Connect the developer board to the aircraft
M350 RTK Aircraft + Accessories (Remote Controller + Battery + Payload + Charger)1Hardware development platform
Laptop/Desktop PC1Connect to aircraft/payload for upgrades and simulator use
USB to TTL Serial Module1Connect the developer board to E-Port Developer Kit
USB-C to USB Cable1Connect the aircraft's USB-C port for aircraft/payload upgrades and simulator use on PC
Micro USB Cable1Connect the developer board to E-Port Developer Kit
USB-C OTG Adapter Cable1Connect the developer board to E-Port Developer Kit
2.54mm Dupont LinesSeveralConnect the developer board to E-Port Developer Kit
2. Hardware Connection
  1. Prepare a high-definition monitor, a keyboard, a mouse, and a clean workspace.
  2. Setup a M350 RTK aircraft, install the battery, and place the aircraft in an appropriate position on the workspace.
  3. If flight control is needed, connect the aircraft's USB-C port (next to the E-Port interface) to a laptop or desktop PC with a USB-C cable.
  4. Refer to the Figure. Aircraft Device Connection and connect the E-Port Developer Kit to the aircraft:
    • Ensure the power switch (Marker 7) on the E-Port Developer Kit is in the OFF position.
    • Connect the USB-C port (Marker 2) of the E-Port Developer Kit to the aircraft's E-Port, and note the A/B sides.
  1. As depicted in the Figure. Jetson Nano and Figure. Jetson Nano Developer Board Connection, connect the E-Port Developer Kit to the Jetson Nano Developer Board. For details about the 40-pin GPIO on the developer board, see the Pin Introductionopen in new window.
    • Use dupont lines to connect the UART (Marker 5) on the E-Port Developer Kit to the USB to TTL Serial Module (TX, RX, and GND of the Developer Kit to RX, TX, and GND of the serial module respectively).
    • Connect the USB to TTL Serial Module to the USB port (Marker a) of the Jetson Nano Developer Board.
    • Set the USB host/device toggle switch (Marker 3) on the E-Port Developer Kit to the Host position.
    • Using the USB-C OTG adapter and Micro USB cable, connect the USB (Marker 6) on the E-Port Developer Kit to the Micro USB OTG (Marker b) on the developer board.
    • Connect the PPS pin (Marker 5) on the E-Port Developer Kit to pin 7 (Marker f) on the 40-pin GPIO of the developer board. For time sync purposes, refer to the Pin Introductionopen in new window. Skip this step if time sync isn't necessary.
    • Using the XT30 to DC power cable, connect the power output interface (Marker 4, 12V/2A or 5V/2A) on the E-Port Developer Kit to the DC power interface (Marker c, use outer power supply if is needed) on the Developer Board.
    • Connect the HDMI output (Marker d) of the Developer Board to the monitor. Connect the keyboard and mouse to the USB port (Marker a), and a wireless network interface controller or Ethernet cable with internet capabilities to the Ethernet port (Marker e) of the developer board, respectively.
    • Make sure all connections are secure and correct.
Figure. Jetson Nano
  1. Start the aircraft, turn on the power switch of the E-Port Developer Kit, ensure the green LED indicator is on and no red LED indicators are active, and check if the developer board is powered on.
  2. Monitor the display to make sure that the developer board has entered the startup page.
Software Environment Setup
1. Set Up the Software Environment
  1. The Jetson Nano Developer Kit does not include an SD card and system image by default. Follow the Nvidia Write Image to the microSD Cardopen in new window for image programming and account setup.
  2. After completing the Hardware Setup and startup, enter your configured account and password to check if you can log into the Ubuntu desktop system.
  3. On the desktop, verify the Jetson Nano's network connectivity using any browser webpage.
  4. Before running PSDK, install the following dependencies using the shell commands provided. Ensure successful installation.
    • FFmpeg
    • ffplay
    • OpenCV
    • libaio
    • CMake
    • libusb
    /* Update software repository */
    sudo apt-get update
    sudo apt-get upgrade
    sudo apt-get install automake
    sudo apt-get install libaio-dev
    /* Download opus-1.3.1 source code from https://opus-codec.org/ and install */
    tar -xzvf opus-1.3.1.tar.gz
    cd opus-1.3.1/
    autoreconf  -f  -i
    ./configure
    make -j16
    sudo make install
    /* Download and install FFmpeg 4.3 source code from GitHub */
    tar -zxvf ffmpeg-4.3.2.tar.gz
    ./configure --enable-shared
    make && make install
    /* Verify OpenCV installation */
    opencv_version
    /* Install libusb */
    sudo apt-get install libusb-1.0-0-dev
2. Enable Jetson Nano's USB bulk function
PSDK offers a Jetson Nano Usb Bulk Configuration Fileopen in new window,including the configuration script (psdk-usb-configure.sh) and configuration program (startup_bulk).
/* Back up the bulk configuration file of jetson nano */
cp /opt/nvidia/l4t-usb-device-mode-start.sh ~/Desktop/nano-usb-config/l4t-usb-device-mode-start-bk.sh
/* Using PSDK's bulk configuration file */
sudo cp startup_bulk/psdk-usb-configure.sh  /opt/nvidia/l4t-usb-device-mode-start.sh
/* Set the startup_bulk file path in the script */
/home/dji/Desktop/startup_bulk/startup_bulk /dev/usb-ffs/bulk1 &
/home/dji/Desktop/startup_bulk/startup_bulk /dev/usb-ffs/bulk2 &
/* After restarting the system, make sure that startup_bulk is running normally */
ps -aux | grep startup_bulk
3. Register for a PSDK Developer Account
Register on the DJI Developer websiteopen in new window to become a PSDK developer.
4. Download PSDK Software Package
Retrieve the latest PSDK software development package from the Payload-SDK repositoryopen in new window on master branch.
5. Update Required Configuration Code
After creating an application in the developer user center, input the generated PSDK application information into the specified files from the previously downloaded PSDK software package. PSDK can not run without filling in the information.
  • samples/sample_c/platform/linux/nvidia_jetson/application/dji_sdk_app_info.h
  • samples/sample_c++/platform/linux/nvidia_jetson/application/dji_sdk_app_info.h
/* Exported constants --------------------------------------------------------*/
// ATTENTION: User must goto https://developer.dji.com/user/apps/#all to create your own dji sdk application, get dji sdk application
// information then fill in the application information here.
#define USER_APP_NAME               "your_app_name"
#define USER_APP_ID                 "your_app_id"
#define USER_APP_KEY                "your_app_key"
#define USER_APP_LICENSE            "your_app_license"
#define USER_DEVELOPER_ACCOUNT      "your_developer_account"
#define USER_BAUD_RATE              "460800"
Based on the connection between the aircraft and the Jetson Nano Developer Board, modify the PSDK hardware connection configuration file accordingly.
  • samples/sample_c/platform/linux/nvidia_jetson/application/dji_sdk_config.h
  • samples/sample_c++/platform/linux/nvidia_jetson/application/dji_sdk_config.h
#define DJI_USE_ONLY_UART                  (0)
#define DJI_USE_UART_AND_USB_BULK_DEVICE   (1)
#define DJI_USE_UART_AND_NETWORK_DEVICE    (2)
/*!< Attention: Select your hardware connection mode here.
#define CONFIG_HARDWARE_CONNECTION         DJI_USE_UART_AND_NETWORK_DEVICE
If using the DJI_USE_UART_AND_NETWORK_DEVICE connection, configure the currently used wireless network interface controller device name, VID, and PID in the following files.
  • samples/sample_c/platform/linux/nvidia_jetson/hal/dji_network.h
  • samples/sample_c++/platform/linux/nvidia_jetson/hal/dji_network.h
/** @attention  User can config network card name here, if your device is not MF2C/G, please comment below and add your
 * NIC name micro define as #define 'LINUX_NETWORK_DEV   "your NIC name"'.
#ifdef PLATFORM_ARCH_x86_64
#define LINUX_NETWORK_DEV           "enxf8e43b7bbc2c"
#else
#define LINUX_NETWORK_DEV           "l4tbr0"
#endif
 * @attention
#define USB_NET_ADAPTER_VID                   (0x0B95)
#define USB_NET_ADAPTER_PID                   (0x1790)
#else
#define USB_NET_ADAPTER_VID                   (0x0955)
#define USB_NET_ADAPTER_PID                   (0x7020)
#endif
If using the DJI_USE_UART_AND_USB_BULK_DEVICE connection, configure the current USB Bulk endpoint in these files:
  • samples/sample_c/platform/linux/nvidia_jetson/hal/hal_usb_bulk.h
  • samples/sample_c++/platform/linux/nvidia_jetson/hal/hal_usb_bulk.h
#define LINUX_USB_BULK1_EP_OUT_FD               "/dev/usb-ffs/bulk1/ep1"
#define LINUX_USB_BULK1_EP_IN_FD                "/dev/usb-ffs/bulk1/ep2"
#define LINUX_USB_BULK1_INTERFACE_NUM           (2)
#define LINUX_USB_BULK1_END_POINT_IN            (0x83)
#define LINUX_USB_BULK1_END_POINT_OUT           (2)
#define LINUX_USB_BULK2_EP_OUT_FD               "/dev/usb-ffs/bulk2/ep1"
#define LINUX_USB_BULK2_EP_IN_FD                "/dev/usb-ffs/bulk2/ep2"
#define LINUX_USB_BULK2_INTERFACE_NUM           (3)
#define LINUX_USB_BULK2_END_POINT_IN            (0x84)
#define LINUX_USB_BULK2_END_POINT_OUT           (3)
#define LINUX_USB_VID                         (0x0B95)
#define LINUX_USB_PID                         (0x1790)
#else
#define LINUX_USB_VID                         (0x0955)
#define LINUX_USB_PID                         (0x7020)
#endif
6. Compilation and Execution
The PSDK software package supports CMake compilation. Use the cmake command to compile and generate executable files. Executing the example code below creates executable files dji_sdk_demo_on_jetson and dji_sdk_demo_on_jetson_cxx in the build/ directory.
cd Payload-SDK/
mkdir cmake-build-debug && cd cmake-build-debug
cmake ../  && make -j8
Sample Introduction
The PSDK offers plenty of sample features and interfaces, catering to second development needs across various industry scenarios. Here's a walkthrough of some key functions to get you started with PSDK development.
Sample: Custom Widget
PSDK supports the Custom Widget Functionopen in new window. The following sample demonstrates how to utilize the API interface to display pre-set custom widget UI in the Pilot.
Run the executable file dji_sdk_demo_on_jetson_cxx.
  • Enter g to select Sample - Start widget all features sample and activate the custom widget feature.
  • Enter h to select Sample - Start widget speaker sample and activate the speaker feature.
Both the custom and speaker widgets display on the Pilot that installed on the remote controller. You can then interact with these widgets in the Pilot.
Figure. Custom Widget Function Sample Result
Figure. Speaker Widget
2. Sample: Information Management and Flight Control
PSDK supports both Information Managementopen in new window and Flight Control Functionopen in new window. This sample shows how to use the API interface to subscribe to M350 RTK aircraft telemetry data and control its motion.
  • Enter 0 to select Sample - Fc subscribe sample and initiate data subscription.
  • Connect the aircraft to the DJI Assistant 2 on your PC, then launch the simulator in DJI Assistant 2. Once set up, enter 1 to 6 to try the flight control feature.
Figure. Information Management Sample Result
3. Sample: Camera and Gimbal Management Function
PSDK supports Camera Managementopen in new window and Gimbal Managementopen in new window features. This sample illustrates how to use the API to control camera photography and gimbal rotation. For camera model support details, refer to the Camera Support Feature Comparison Table in Basic Camera Managementopen in new window.
  • Enter k to select Sample - Run camera manager sample and try the camera management feature.
  • Enter a to select Sample - Gimbal manager sample and try the gimbal management feature.
Figure. Camera Function List
Figure. Camera Management Sample - [11] Record video
Figure. Gimbal Function List
4. Sample: Camera Stream Subscription
PSDK supports the Camera Liveview Functionopen in new window. This sample demonstrates how to use the API to subscribe to the M350 RTK FPV and main camera streams.
Enter c to select Sample - Camera stream view sample and experience both the camera and FPV stream subscriptions.
Figure. Subscribe Camera Stream
Figure. Main Camera
Figure. FPV Camera
FAQ
Frequently Asked Questions
  1. Error when running PSDK:
Can't operation the device. Probably the device has not operation permission. Please execute command 'sudo chmod 777 /dev/ttyUSB0' to add permission.
Solution: Run sudo chmod 777 /dev/ttyUSB0
Please fill in correct user information to 'samples/sample_c/platform/linux/nvidia_jetson/application/dji_sdk_app_info.h' file.
Solution: dji_sdk_app_info.hPlease create an account on developer website, and fill in the relevant information to file dji_sdk_app_info.h.
  1. Error when running PSDK::
ls: cannot access '/dev/ttyUSB0': No such file or directory
Solution: Check if the serial port is connected correctly.
Other Questions
Please go to Technical Documentsopen in new window, PSDK Knowledge Libraryopen in new window, DJI Forumopen in new window, and Submit Requestopen in new window to get more technical support.
