选择开发平台
请根据操作系统和开发平台对PSDK 功能的支持差异、负载设备程序的资源占用情况以及PSDK 支持的工具链,选择开发负载设备的操作系统和开发平台。
选择飞行平台
机型功能差异
说明:
M300 RTK 云台口指:上置云台口(1个),下置云台口(2个)。图示可参考设备连接。
功能名称 | Mavic 3E/3T E-Port 接口 | Matrice 30/30T E-Port 接口 | M300 RTK 云台口 | M300 RTK OSDK接口 | M350 RTK 云台口 | M350 RTK E-Port 接口 | FlyCart 30 E-Port Lite 接口 | Matrice 3D/3TD E-Port 接口 | Matrice 3D/3TD E-Port Lite 接口 | Matrice 4E/4T E-Port 接口 | Matrice 4E/4T E-Port Lite 接口 | Matrice 4D/4TD E-Port 接口 | Matrice 4D/4TD E-Port Lite 接口 |
日志管理 | ✓ | ✓ | ✓ | ✓ | - | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ |
数据订阅 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ |
基础相机功能 | ✓ | ✓ | ✓ | - | ✓ | - | - | - | - | ✓ | - | ✓ | - |
基础相机管理 | ✓ | ✓ | - | ✓ | - | ✓ | - | ✓ | - | - | - | - | - |
云台功能 | ✓ | ✓ | ✓ | - | ✓ | - | - | - | - | ✓ | - | ✓ | - |
云台管理 | ✓ | ✓ | - | ✓ | - | ✓ | - | ✓ | ✓ | - | - | - | - |
电源管理 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | - | - | - | - |
飞行控制 | ✓ | ✓ | - | ✓ | - | ✓ | ✓ | ✓ | - | - | - | - | - |
自定义控件 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ |
自定义HMS 功能 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ |
HMS 管理功能 | ✓ | ✓ | - | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | - | - | - | - |
时间同步 | ✓ | - | ✓ | - | ✓ | ✓ | - | ✓ | - | ✓ | - | ✓ | - |
低速数据传输 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ |
视频流传输 | ✓ | ✓ | ✓ | - | ✓ | - | - | - | - | ✓ | - | ✓ | - |
回放下载 | - | - | ✓ | - | ✓ | - | - | - | - | - | - | - | - |
X-Port 功能 | - | - | ✓ | - | ✓ | - | - | - | - | - | - | - | - |
获取相机码流 | ✓ | ✓ | - | ✓ | - | ✓ | - | ✓ | - | - | - | - | - |
本地升级 | ✓ | ✓ | ✓ | - | ✓ | - | - | ✓ | - | ✓ | - | ✓ | - |
高速数据传输 | - | - | ✓ | - | - | - | - | - | - | - | - | - | - |
精准定位 | - | - | ✓ | - | ✓ | - | - | - | - | - | - | - | - |
SDK互联互通 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | - | - | - | - | - | - | - |
运动规划 | ✓ | ✓ | - | ✓ | - | ✓ | ✓ | ✓ | - | - | - | - | - |
喊话器控件 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | - | ✓ | - | ✓ | - |
选择操作系统
平台功能差异
功能名称 | 平台支持-Linux | 平台支持-RTOS |
日志管理 | ✓ | ✓ |
信息管理 | ✓ | ✓ |
基础相机功能 | ✓ | ✓ |
基础相机管理 | ✓ | ✓ |
云台功能 | ✓ | ✓ |
云台管理 | ✓ | ✓ |
电源管理 | ✓ | ✓ |
飞行控制 | ✓ | ✓ |
自定义控件 | ✓ | ✓ |
HMS 功能 | ✓ | ✓ |
时间同步 | ✓ | ✓ |
低速数据传输 | ✓ | ✓ |
视频流传输 | ✓ | ✓ |
回放下载 | ✓ | - |
X-Port 功能 | ✓ | ✓ |
获取相机码流 | ✓ | - |
本地升级 | ✓ | ✓ |
高速数据传输 | ✓ | - |
精准定位 | ✓ | ✓ |
SDK互联互通 | ✓ | - |
运动规划 | ✓ | ✓ |
喊话器控件 | ✓ | ✓ |
资源占用
Linux
使用Manifold 2-C 运行Linux 平台PSDK 示例程序,程序运行时的资源占用情况如下所示:
- 栈:约 12288 字节
- 堆:约 40960 字节
- Text 段:755359 字节
- Data 段:3872 字节
- Bss 段:23848 字节
- CPU 占用:7.2 %
RTOS
使用STM32F407IGH6-EVAL 运行RTOS 平台PSDK 示例程序,程序运行时的资源占用情况如下所示:
- Text 段:353620 字节
- Data 段:1836 字节
- Bss 段:85620 字节
- CPU 占用:30 %
选择开发平台
PSDK 支持使用如下工具编译基于PSDK 开发的负载设备,请根据选用的开发平台正确地选择工具链。
工具链名称 | 目标平台 | 典型芯片型号 | 推荐开发平台 |
aarch64-linux-gnu-gcc | aarch64-linux-gnu | NVIDIA Jetson TX2、Rockchip RK3399 pro | Manifold2-G、瑞芯微Toybrick开发板 |
x86_64-linux-gnu-gcc | x86_64-linux-gnu | 64位intel处理器,如 Intel Core i7-8550U | Manifold2-C |
arm-linux-gnueabi-gcc | arm-linux-gnueabi | ZYNQ、I.MX6Q | - |
arm-linux-gnueabihf-gcc | arm-linux-gnueabihf | 支持硬件浮点运算的处理器,如OK5718-C等 | - |
armcc-cortex-m4 | Cortex M4/M4F系列MCU | STM32F407IGT6、STM32F405RGT6 | STM32F407-Eval、STM32F407探索者开发板等 |
说明: 开发者需根据所使用的开发平台,选择指定编译链的静态库。若开发包中没有所需编译链的静态库,请提供开发负载设备时使用的开发平台的型号、编译链的型号和编译链的安装包发送给SDK 技术支持团队,我们将为您准备相应的工具链编译的静态库。
