Environment Preparation
2022-07-22
No Rating
The Cloud API demo is designed with a separate front-end and back-end, using the TS+Vue3 framework for the front-end and the JAVA language for the back-end (must be 11 and above, otherwise, the back-end code will not compile) and the Spring Boot framework. To use this demo, the user needs to be familiar with the following knowledge in advance.
  • Front-end
  1. TypeScript, HTML, CSS.
  2. Vue3.x, Node.js npm.
  3. Ant Design Vue V2
  4. HTTP/Websocket
  5. The Linux environment deploys front-end application services via Nginx.
  6. Open API for amap.
  • Back-end
  1. Java
  2. Spring Boot
  3. MQTT
  4. MySQL
  5. WebSocket
  6. Redis
  • *Environment & Versions
  1. Linux, Ubuntu16.04
  2. Java version: openJDK must be 11 and above.
  3. MySQL version: 8.0.26
  4. EMQX version: 4.4.0
  5. Redis 版本:6.2
  6. Nginx version: 1.20.2
  7. Vue version: 3.0.5
  8. Node.js version: 17.8
  • Demo Download
  1. Click to download the front-end source code.open in new window
  2. Click to download the back-end source code.open in new window
  3. If you don't want to install the development environment, you can try deploying with docker. Click the link to download.open in new window
