Media Library
Function Overview
The media library is the function that helps Pilot2/DOCK to upload the photos/videos, downloaded from aircraft to the remote controller/dock, to the 3rd party server. Media upload function includes auto upload or manual upload. For DJI Dock, it has auto upload only.
Media object storage support OSS and S3. The demo example is based on Aliyun OSS test, if you encounter other storage buckets that can not be uploaded, please contact us.
Interactive timing diagram of DJI Pilot 2
Pilot API Detailed Realization
Load Media Library Module
Before using the media library module, developer needs to set up the workspace ID in H5 through JSBridge, configure API module, and then load the DJI Pilot 2 media module. Also, developers can consider adding the loading interface of Media Library module in log-in phase.
API: Refer to App API > JSBridge API Reference window.djiBridge.platformLoadComponent(String name, String param)
Media Fast Upload
As the transfer of files may exist in the cloud of existing images, then DJI Pilot 2 or dock will start the file fast transfer interface when uploading files, the server needs to check whether the file has been uploaded exists, if it exists, directly return the upload success.
API: Refer to Server API Reference > HTTP > Media Management > Media Fast Upload
Obtain Exist File Tiny Fingerprint
For whether the file exists or not, the corresponding fingerprint verification needs to be done, but since media files vary in size, DJI provides a set of media file streamlined fingerprint generation scheme, and the server side only needs to calculate the media fingerprint information according to this scheme and return it to the DJI Pilot 2 side.
API: Refer to Server API Reference > HTTP > Media Management > Obtain Exist File Tiny Fingerprint
Obtain Temporary Credential
For each media upload, you need to obtain temporary file upload credentials from the server, so that DJI Pilot 2 will bring the credentials to the object storage service for verification when uploading.
API: Refer to Server API Reference > HTTP > Media Management > Obtain Temporary Credential
App Reports File Upload Result
After the media file transfer is finished, DJI Pilot 2 will call this interface to inform the server of the corresponding media file upload result.
API: Refer to Server API Reference > HTTP > Media Management > App Reports File Upload Result
